In PWP 8.0.533 when Gaussian Precise is running, the window through which you can cancel the transformation says Shift + Alt to cancel instead of Ctrl + Alt.
When a script that uses Gaussian Precise is running, it is no longer possible cancel just the transformation and allow the script to proceed to the next transformation. The only operation that seems possible is cancelling the entire script. It would be nice to be able to cancel either just the current transformation or the entire script.
Cancelling
Re: Cancelling
I already fixed the incorrect message in the dialog box for the next release.
I will look into implementing your suggestion for optionally proceeding within a script.
