Saving Custom Crop ratios
Well, reading the reviews of the new Fuji GFX100RF camera, and their decision to make different cropping modes quickly available via a command dial, it got me thinking about the list of cropping ratios in the Crop Transformation.
I use the custom option from time to time, and wonder if it would be possible to add our own ratios to the drop-down list so I wouldn't have to type them in each time I want to deviate from the preset list? (This is possible to do in Faststone Image Viewer...)
Thanks for the consideration.
Mark
Re: Saving Custom Crop ratios
Not sure if this will suffice, but if you Save Settings with a custom ratio, you could reload it later and the ratio under Custom will be preserved. You can save several settings, each with different custom ratio.
Good idea Maciej, thank you.
That's three clicks instead of two ;-), but does the trick. For the amount of times I create 'new' crop ratios this will suffice.
