Multiple "Missing source image" warnings
If you close an image (or the whole tree) which is an auxiliary image for a clone transformation and then you go on to open the clone transformation, you get multiple error warnings : Missing source image. If you keep closing them, you finelly get to open the transformation.
It looks like the number error instances corresponds to the number of clone strokes made from the auxiliary image.
This is not about the warning itself, which is OK, this is about its multiple popping ups.
This happened after I bypased the clone transformation for later reuse and then deliberately removed the whole tree with the auxiliary image.
Re: Multiple "Missing source image" warnings
Fixed for next release - Missing source image will now only be reported once.
