An update is available to Picture Window 8.0.244 and Slide Show Viewer 1.0.4 (29-Oct-2021)
Linear Gradient Transformation: fixed problems with 16-bit B&W images for brightness adjust modes.
Slide Show Viewer: Fixed some memory leaks and memory de-allocation errors that could cause crashes in some cases as well as some other problems. Added multiple image selection and cut/copy/paste of multiple slides.
Update Available - Picture Window 8.0.244 and Slide Show Viewer 1.0.4
Re: Update Available - Picture Window 8.0.244 and Slide Show Viewer 1.0.4
In the Slide Show Viewer, would it make sense to gray out the File/New Slide Show... if there is no slide show open - I keep clicking on it thinking that it will bring up a file picker or new slide show setup dialog box...
