Update Available - Version 8.0.220
An update is available to Version 8.0.220 (9-Jun-2021)
Minor changes to Favorites processing.
Updated to ExifTool 12.26
File Open: if file does not exist and you set a different drive letter, the pathname in the file list is now updated so that when you save the script it contains the new pathname.
Added a third button to the horizontal/vertical split screen tool bar to support automatic selection of horizontal or vertical based on the input image dimensions and the size of the main image area.
One new bitmap requires a full install.
Fixed problems with Alt key deselecting main window on every other key press.
Added support for latest Nik 4 plug-ins.
