Update Available - Version 8.0.186
An update is available to Version 8.0.186 (27-Dec-2020)
Line/Arrow/Text Tool: To make it easier to edit control points, you can now right-click on the input image and select one of four commands from a popup menu. The commands are: Add a control point, Add a new line/arrow/text, Remove control point, Remove entire line/arrow/text.
Geotagging is now incorporated into the File/Copy Card to Folder command. This is done using ExifTool which can extract location data from an optional GPX file you supply and add it to the image file metadata for all the files in a folder.
New File/Geotag Folder command: similar to the above but you can geotag any image folder you want as long as you have the corresponding GPX file.
Added ProPhoto.icm to the list of ICC profiles Picture Window installs when it starts up. You will need to do a full install to get this profile.
