Update Available - Version 8.0.103
An update is available to Version 8.0.103 (21-May-2020)
Speck Removal Tool: undid previous changes and fixed some problems with the original patch match algorithm.
File Export: when you click OK, if you are saving to the output image, an Export transformation remains behind so as to retain the output image. Also, fixed problems with exporting with Profile set to None.
