Update Available - Version 8.0.12
An update is available to Version 8.0.12 (25-Nov-2019)
Levels and Color Tool: performance optimizations.
Quick Pick: the first letter you type now matches the first letter of any word in the transformation name -- not just the first word. For example “g” now matches “Linear Gradient” as well as “Grid”.
File Save: the proposed version number is now determined by adding one to the largest existing version number for the file in its folder. This guarantees the version with the largest number is the most recently saved (assuming of course you do not rename the files yourself).
File Save and File Export: when saving or exporting image files or when specifying file save preferences, there is now a new script option – Include script with image copies. This lets you save all the original files along with the final image and a script to rebuild the final image from the original files.
Added a new Watermark transformation for applying a watermark or logo image to a photograph. See the updated help file for details.
Re: Update Available - Version 8.0.12
Please consider the new Watermark transformation in this release experimental -- I will probably be changing the way it works slightly in the next release and scripts using it may stop working.
