Some Layout inconsistencies
1. open Layout, load an image, resize the panel cropping rectangle
2. Choose either of Fit panel scale... proportions, make the panel cropping rectangle a small part of the image and place the image cropping to the center of the image
3. Click alternately on vertical and horizontal Orientation buttons -> the crop rectangle will move diagonally along the image
There does not seem to be a way to make a portrait crop oriented horizontally (rotated 90 degrees) with Fit panel - scale .. proportions
1. choose either of Fit panel scale... Proportions
2. make a landscape oriented crop of part of the image
3. click on either of the horizontally oriented arrows (Rotate 90 degrees) -> the crop always gets filled vertically leaving blank spaces left and right of the cropped image.
It is possible to drag the sides of the panel cropping rectangle outside the panel - you can check it in the preview - which makes the cropped image distorted.
