Bug fix release 30-Sep-2018
I have posted a new release (30-Sep-2018) in full installer and executable-only versions. Minor changes to help file.
Fixed problem with File Open not starting in the last folder opened.
Added File/Preferences setting to let you customize the time delay between when you stop typing and when the program responds (normally 2 seconds). If you are a slow typist, you can increase the delay, but if you are impatient you can shorten it.
Fixed problem where closing an image via the image browser while its dialog box was open closed the dialog box but not the image. This involves undoing a change I made a while ago, but I don’t remember why I made the original change, so some other problem related to closing or canceling transformation dialog boxes may reappear.
Fixed problem with the Windows modal dialog boxes not de-activating the transformation dialog, mask dialog, color pickers or other popup windows, possibly causing a crash.
