Bug fix release 28-Aug-2018
I have posted a new release (28-Aug-2018) in full installer and executable-only versions. Minor changes to help file.
Equalize: Fixed problems with initial curve display and for 16-bit image curve display.
Adjust: Added RGB as a color space option for the Curves tab. Switching color spaces now resets curves. Added separate color space control to the Color tab for adjusting saturation, although the difference between HSV and HSL saturation adjustment is subtle. Fixed bug with adjusting saturation of 48-bit color images in HSV color space.
Added Redeye Removal Tool, similar to the one in PWP 7.2 but that operates more or less like Speck Removal. See updated help file if you need more information.
Re: Bug fix release 28-Aug-2018
Possibly new issue with Adjust - "Illegal Adjust command" and "Illegal Adjust command line" errors appear when first opening transformation. They go away with clicks, and then Adjust works as normal.
Update: A few images later, and Adjust opens without errors, but now Sharpen opens with the same two errors... Not sure what's happening. I've opening transformations by typing, but I also tried it by menu selection and have had the same results.
Also note that when Quick Pick list is opened, Add Border cannot be opened by mouse click, but typing "add b" works. "addb" does not work, and opening my menu selection works.
The command syntax changed with the new adjust command so existing scripts, including default settings, were invalidated. Re-saving the default settings should solve any future problems.
Ah, yes resetting the defaults did the trick. Thank you.
I hope to address this issue shortly so these fixes will not be necessary in the future as missing command line arguments will just be set to default values automatically.
