Bug fix release 12-Aug-2018
I have posted a new release (12-Aug-2018) in full installer and executable-only versions. No changes to help file.
Paint and Clone Tools: implemented more efficient undo that, for each stroke, only saves the areas you paint or clone, not the entire image.
Quick Pick: fixed memory leak.
Color Balance: Moved Full Range from Settings Menu to the White control (this may invalidate some existing scripts that incorporate Color Balance). Fixed problems of auto white balance not being recomputed when switching input images and other related problems.
Multi Color Balance: Fixed problems with colors changing on Reset and not being set correctly in some other cases.
