Adjust Color boosts Curve
3-Aug. version
Adding or Removing a color cast boosts (multiplies ?) the Curve effect. When you brighten the image with the Curve, Color brightens it even more. When you darken it, Color darkens it more.
It happens even when you turn the Curve off with its mode button. Only if you reset the curve to its default neutral shape does the Color work as expected.
