Crash when Loading a previously Saved Mask
Ref: PWP 8.0.exe 180729 and 180728
1) open an image, 8 or 16 bit, color or black/white, tiff or jpeg
2) open any transform and make approriate settings
3) select New mask; make appropriate settings; and Apply
4) Save the mask file
5) Reset the Mask dialog
6) re-Load the 4) mask file
PWP disappears from desktop with no warnings
Re: Crash when Loading a previously Saved Mask
Not seeing this here.
I still have the problem after an un-install; clean registry; and an install 180726 msi with 180729 PWP 8.0.exe update.
Will check further and advise but not today.
the latest Alpha release
I can confirm this using the folloving steps or settings:
Transformation: Color balance (have not tried others)
1. Tool masks: Curve, Flood fill, Texture (have not tried others)
When you reload a saved mask, PWP stops working and has to be killed. It does not disappear, but it may be because of different OS. I still use Win7, while den probably Win10.
2. "Half" masks and geometrical shapes
You are able to reload a saved mask, but when you try to reset the mask dialog again, PWP stops working....
Thanks for the details, I fixed it for the next release.
This is to advise that I am no longer having this problem with the PWP 8.0.exe 180730-5 and 180731 updates.
Thank you davidh for your input and Jonathan for your updates.
