Bug fix release 21-Jun-2018
I have posted a new release (21-Jun-2018) in full installer and executable-only versions. Minor changes to help file.
Fixed bugs in Resize transformation related to setting memory size.
If a file is missing when trying to run a script, the error message is now correct, and you can provide a replacement file. Also fixed problems with errors not being cleared when you replace a file in a File Open.
Fixed problems causing close of transformation dialog not to propagate changes downstream. Recalc now preserves the current image. To see the end result, press the End key to go to the end of the current branch.
Fixed crash when pressing the End key to go to the end of the current branch.
