Color management in PW8 - need help...
Posted: April 17th, 2025, 5:30 am
OK...i am opening CR2 files (Canon) using PW8 (latest version), on a Win11 system.
The monitor is calibrated, and the custom color profile is set as a default profile in Display Settings in Windows.
The Color Management Settings in PW8 are shown in the attached image 'PW8_CM_Settings.jpg'.
The CR2 image opens just fine, and its color profile is converted from 'None" to the monitor profile...and here is the problem:
The same CR2 image is also opened in Digital Photo Professional v4, and also in GIMPv3. Both DPP4 and GIMP have their color management set 'On', with appropriate settings applied.
The images in DPP4 and GIMP are identical. The exported TIFFS contain color profile. The TIFFs look identical - viewed either in DPP$, or GIMP, or in Photos (Windows app) - as they should.
The CR2 image opened in PW8, however, is distinctly darker. It is converted to the same image profile, but the image opened in PW8 and the TIFF exported with the color profile embedded are much darker than the images from DPP or GIMP.
To my understanding - if the same RAW data is converted to the same color profile - it should look identical, irrespective of the editor used.
The reality is as shown in the attached image 'Comparison_3_editors.jpg'
So - what might be the problem? It is usually located between the chair and the keyboard...but I can't figure out what might be wrong.
I can deal with Photoshop, GIMP, DPP, Lightroom and get exactly the same results from each - but not with PW8...
Any insight would be greatly appreciated...
