Update Available - Version 8.0.488
Posted: March 13th, 2025, 10:47 am
An update is available to Version 8.0.488 (13-Mar-2025)
Palette Tool: if Display Palette in Main Image Area is checked, the on-screen palette now allows extra space for scroll bars.
Export: Added two new options to the Folder setting – Original Subfolder and Ask. Original Subfolder lets you specify the export folder as a subfolder of the original folder. If you select Ask, Picture Window asks you for a folder to export to at the beginning of a batch process (or every time if not in a batch process). See the updated help file or Transformations.pdf for more details.
The File Overwrite dialog box that warns you when you are about to save over an existing file can now be resized horizontally to accommodate wider pathnames.
Batch: you can now run a batch job on a single file.
