Update Available - Version 8.0.268
Posted: January 16th, 2022, 4:43 pm
An update is available to Version 8.0.268 (16-Jan-2022)
Added a new transformation: Color/Hue Saturation. Please see the help file for details – Transformations.pdf has not yet been updated. This transformation should be considered experimental at this point and possibly subject to change in future releases. It is based on the hue-saturation histogram and lets you make saturation, brightness and hue changes to images based on selections within the histogram.
Mobius transformation: fixed bug in calculation of Mobius function, so the color wheel is now distorted a little differently.
Added File/Re-Save command to main menu. This command is grayed out unless the current image was previously saved along with its script file and the script was subsequently reloaded. The command then saves the current image with the same name as it was saved under the last time, overwriting the previously saved version. You still get a confirmation message asking if you want to overwrite the file or choose a different pathname. Use this command after you re-work an image and want to overwrite the previous version with the new version instead of incrementing the version number and saving another copy.
Fixed a problem with an incorrect “last saved as” pathname being stored in script files in some cases. Consequently, when using pre-existing scripts, information about the pathname and date of the saved image file is now discarded when loading a script. The next time you save the image file with a script, however, the correct information will be written out and File/Re-Save should work correctly from then on.
Clone tool: “Missing source image” warning message is now issued only once, even if there are multiple missing images or strokes using the missing image.
