Update Available - Version 8.0.250
Posted: November 16th, 2021, 7:00 am
An update is available to Version 8.0.250 (16-Nov-2021)
Brightness Curve: fixed problem with Bilateral/Guided setting not being preserved when re-opening the transformation.
File/Save Back command: if you recently opened a script file, the starting folder for saving is set to the folder containing the script file. Otherwise, the folder holding the original file is used as before. Thus, if you open a file for editing by opening its script file, when you save an image, it will suggest the same folder as the script. If you create an image without opening a script file, it will suggest the folder from which the original image was derived, if any.
