Update Available - Version 8.0.236
Posted: August 25th, 2021, 9:52 am
An update is available to Version 8.0.236 (25-Aug-2021)
File/Card to Folder: added yyyy\mm option when copying by date.
Updated Transformations.pdf and Curves and Histograms.pdf with new examples of lightening and darkening using HSV and HSL.
Brightness Curve: Color Space (HSV/HSL) is now be assigned independently to the Black and White curves. Previously there was a single setting which applied to both curves.
Two-Zone and Three Zone transformations: added an item to Settings menu to select HSV or HSL when adjusting highlights. Default is now HSL, but HSV will be used when processing old script files to maintain backward compatibility.
File/Preferences: added OK and Cancel buttons.
Clone: fixed problems with re-opening transformation after cloning with Recycle set to No.
Re: Update Available - Version 8.0.236
Posted: August 25th, 2021, 10:44 am
I can't figure out how that works.
Posted: August 26th, 2021, 12:11 am
I think I got it now - it works with masks.
Posted: August 26th, 2021, 7:08 am
In File/Card to Folder: the new yyyy\mm option in Settings pull-down menu can not be selected.
Posted: August 26th, 2021, 2:21 pm
