Update Available - Version 8.0.222
Posted: June 25th, 2021, 2:03 pm
An update is available to Version 8.0.222 (25-Jun-2021)
Added a new button to the main tool bar (just to the right of the Close All button) that displays all the top-level File Opens in the image tree. For each File Open, the first pathname in its file list is displayed in a drop-down menu. Selecting a pathname from the menu makes its File Open the current transformation. This provides a convenient way to select a file when you have lots of them open at once. Requires a full install due to one new bitmap.
Image menus: fixed problem with down-arrow key not working properly near the end of long lists. Increased the automatic close time delay from 5 to 10 seconds. You can now use the mouse wheel to move up or down the list.
Dropdown menus: You can now use the mouse wheel to move up or down the list.
Image Browser: hovering over a thumbnail displays its full caption as a tool tip. This lets you see, for example, the full filename of a File Open if it is truncated in the thumbnail title bar. Hovering over auxiliary input or mask thumbnails does not display a tool tip.
Masks: fixed problem of a mask being reset when its transformation was reloaded in certain cases where the mask was based on a mask in another transformation.
