Update Available - Version 8.0.204
Posted: March 12th, 2021, 9:16 am
An update is available to Version 8.0.204 (12-Mar-2021)
Paint, Clone, Smudge, Levels & Color Tools: brush settings now include width and angle buttons, allowing you to make narrow brushes that can be angled to get into small corners. You will need to do a full install to get new bitmaps.
Mask: fixed problem causing crash in certain mask tools when attempting to draw a mask outside the input image.
The pathname a script (or workspace script) file is saved under is now embedded within the script file. This allows Picture Window, in a future release, to check when opening a script file to see if it has been moved from its original location and adjust image file pathnames referenced by the script accordingly.
