Update Available - Version 8.0.162
An update is available to Version 8.0.162 (4-Oct-2020)
Match Reference and Create Profile: added support for Datacolor SpyderCheckr 24 and SpyderCheckr 48 targets. Also fixed some problems in Create Profile transformation causing it to produce an incorrect output image in some cases (the saved profile was OK). If you need to get the reference files for Create Profile, you need to do a full install.
Export: fixed problem causing a superfluous asterisk to be inserted into the filename if the Ask option was specified.
Mask Paint tool: fixed problem of spurious line being drawn after right-clicking on the input image.
