PWP7 posterize settings not compatible with PWP8
Posted: February 2nd, 2019, 7:20 am
by davidh
PWP7 Posterize settings cannot be loaded into PWP8 posterize dialog:
...- commmand line starts with wrong command: Poster
Is there a way to manually edit the PWP7 settings file so as to be accepted by PWP8?
Re: PWP7 posterize settings not compatible with PWP8
Posted: February 2nd, 2019, 7:56 am
It is possible but complicated. Probably more trouble that it's worth.
The easiest way I can think of is to take a screen shot of the pwp7 dialog box and use pwp8's color picker to define the colors.
Posted: February 5th, 2019, 5:08 am
by davidh
I compared contents of both files and yes, it would not be worth it. However, there is still a bit easier or faster way. It just needs to open the PWP 7 .posterize file in Notepad (or a similar text editor) and transcribe the decimal values to the PWP 8 Color picker. They will get saved as hex numbers in PWP8.
