Bug fix release 4-Apr-2018
Posted: April 4th, 2018, 2:02 pm
I have posted a new release (4-Apr-2018) in both full version and executable-only. The only reason to download the full version is to get the latest version of the help file which mostly has some cosmetic edits and information on File Back and File Save As.
Fixed problem with loss of control of cursor when dragging an overlay outside of the image area, e.g. when adjusting a copy box and accidentally dragging it slightly across the separator into the image browser.
There are now two File Save commands: Save Back and Save As. Save Back sets the initial folder to the folder the original image came from (if any), and defaults to the same filename as the original file. Save As sets the initial folder to the last folder you saved files in and defaults the filename to *.*. If there is no original image (i.e. if the top level image from the current branch is not from a File Open), Save Back acts like Save As.
Toggling the bypass button on/off should now display the normal and bypass images with the same zoom and scroll settings if the normal and bypass images have the same dimensions. Otherwise, they zoom and scroll independently.
As with the previous version,
If your preferences are messed up (because the location where preferences are stored has changed), run File/Preferences, re-enter your settings, and click OK.
If you get an error about missing monitor curves on startup, run File/Color Management, set Monitor Curves on Startup to something, then change it to None (unless you want to use Monitor Curves), and click OK and confirm you want to save the settings.
