When compositing, I use the Flood Fill attribute of Masking, quite a bit.
Often, I can't get the entire mask without clicking in many parts of the area(s) that I wish to composite. This means repeated click on the left image, move the cursor to the Apply button, click, then repeat...... And, when I am on a roll, I will often forget to click Apply and have to do that area again.
So, is it possible to designate a key, which one could keep the left hand at, to click rather than doing the current method? Click with right for the Flood Fill, a quick click with the left, etc etc etc. And it would also reduce the eyes having to go back and forth between the image and the Apply button.
As mentioned in another thread, I keep the dialogue boxes on a second monitor, which increases the travel of the mouse (or pen) and eyes. I realize this issue is not as significant for those who have the dialogue box on the main monitor, but I think a key would make it smoother for those as well.
As a comparison, I use another program for some things like removing objects. I use the right hand for the mouse/pen and have the left resting on the space bar to open the hand to move about in the image.
Just a thought,
Composite Masking, Apply
Re: Composite Masking, Apply
Flood fill has a shortcut for this -- Shift-Click on the image does an apply and then initiates a new flood fill.
Perfect. Thanks for the info.
