Update Available - Version 8.0.209
Posted: April 18th, 2021, 3:17 pm
An update is available to Version 8.0.209 (18-Apr-2021)
Added confirmation on Reset from Mask settings menu and from Amount menu.
Amount control: removed Reset from menu if there is no mask to reset.
Copy Card to Folder: fixed problems with Reload Last Settings command, although the Ctrl-R keyboard shortcut cannot be used since it is a modal dialog box.
Compare: fixed problem with scroll bars not being updated on zoom in and out. There is still an issue with the scroll bar position always being reset to the center of the image when you zoom in or out.
Crop transformation was reworked significantly. Dragging a corner of the crop box now resizes it, leaving the center fixed. Rotating the crop box now rotates it about its center and no longer about the center of the image. Fixed other issues with adjusting the crop box when rotated and/or having its proportions fixed.
