Update Available - Version 8.0.205
Posted: March 16th, 2021, 12:38 pm
An update is available to Version 8.0.205 (16-Mar-2021)
Composite: if overlay image is being displayed, the nudge buttons are applied to the overlay alignment points – if the base image is being displayed, the nudge buttons are applied to the base alignment points. Improved robustness of auto-registration of images that are exposed differently. Fixed problem that could cause mask dialog box to become hidden in some cases. Added Refine button to perform sub-pixel refinement of existing alignment points. Auto-alignment is now always followed by a refine as well. If Auto-Align fails to find a good match, you can set the alignment points manually and then use the Refine button to fine tune the alignment points for a better match. You will need to do a full install to get the new Refine icon bitmap.
Fixed display misalignment for Smooth Display set to No.
Keyboard shortcut Ctrl-D, if a transformation dialog box is open, toggles between displaying the input and the output image. Fixed problems with Ctrl-D keyboard shortcut in some cases.
Paint, Clone, Smudge, Levels & Color Tools: fixed problem of rotated non-circular brush outlines leaving bits of the brush overlay behind when moving the cursor.
