I was using the the clone tool (8.8.255 s/w version, Windows) and it looks like it works as expected
until AFTER I perform an undo (via ^z). The cloning after that has a black outline around it.
Thoughts?
John P
Cloning oddity after 'undo'
Re: Cloning oddity after 'undo'
Can you supply more details - does not seem to be happening here.
Let me see what I can find. I'm using Win-8, that may be part of the problem.
It's a 16 bit B&W image. Previous steps included multipass sharpen and brightness curve.
I've attached two screenshots. The after_undo.PNG shows what I'm seeing. You can see the outline
around the area I'm cloning.
If I click OK to accept the image, then re-open the Clone tool, the outlining disappears.
John P
John P
- before.PNG (278.46 KiB) Viewed 1098 times
- after-undo.PNG (114.35 KiB) Viewed 1098 times
