Update Available - Version 8.0.538
An update is available to Version 8.0.538 (28-Nov-2025)
Oval Gradient: Added Shape setting which can be either Oval or Rectangle. Oval produces the same effect as before with the Roundness slider producing squircles (blended rectangle and ellipse shapes). Rectangle is similar, but the Roundness setting produces rectangular shapes with rounded corners.
Oval Gradient Mask Tool: updated as in Oval Gradient transformation above to support rounded rectangle shaped masks.
Mask: fixed crash when switching between 8- and 16-bit masks in some cases when the mask paint tool had been applied.
File New: fixed problem with ignoring changes to text controls in some cases.
File Open: fixed problem of spurious warning about file date in some cases.
