Update Available - Version 8.0.159
An update is available to Version 8.0.159 (29-Sep-2020)
Oval Gradient Mask Tool: now supports rotated ovals similar to the Gradient transformation. It also now preserves the center location when you resize the oval.
Re: Update Available - Version 8.0.159
I can rotate oval by entering the Angle value. Is there a mouse-drag shortcut to it?
For instance: in Crop Shit-left mouse would rotate it. In Oval Gradient Shift-left mouse seems to to set both oval axes to the same value (i.e. circle).
In both the Oval Gradient transformation and the Oval Gradient mask tool you rotate by dragging the line that extends from the center of the oval. Holding down Shift when dragging any of the other control points makes the gradient circular.
Yes. Got it. Cheers!
