Watercolor problems
Watercolor problems
Alpha 16-Aug .
1. I cannot load any watercolored images inside pre Alpha 16-Aug scripts. All of them get red with the error saying bad or invalid input image.
2. When you open the watercolor transformation dialog on a new image, the Display input button is turned on instead of Display Preview (like it is in other transformations with a inbuilt display). Also, the Display input button does not work on the inbuilt preview.
3. When the Display Side by Side button in on, a click on the dialog title bar cancels the split preview.
Re: Watercolor problems
1) Sorry, I changed the script for Watercolor so old scripts will not work. This is something I generally try to avoid and will guarantee not to do after the product is released at which point I will need to accommodate all previous versions of the command syntax.
2) Fixed for next release
3) Fixed for next release
No problem, no real damage to any serious work done.
In fact, it just needed to make a tiny change to Watercolor settings and the outputs and all the dependenet images were recovered.
